Alphacool Apex Grip double nipple OT/OT rotary G1/4 black
ANF Alphacool Apex Grip Doppelnippel AG/AG drehbar G1/4 schwarz
  • 14809
  • 4250197148092
  • 0,047 kg
  • 5
€4.98 *
Technical Data
Height28,00mm
Diameter19,40mm
MaterialBrass
Material Grip SurfaceSilicone
Threads2x G1/4
Thread Length5mm
Warranty: 5 years
