Alphacool Core Geforce RTX 5080 Solid + AMP with backplate
  • 14733
  • 4250197147330
  • 1,666 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- Zotac Gaming GeForce RTX 5070 Ti AMP Extreme Infinity (ZT-B50710B-10P)
- Zotac Gaming GeForce RTX 5070 Ti Solid OC (ZT-B50710J-10P)
- Zotac Gaming GeForce RTX™ 5080 AMP Extreme Infinity (ZT-B50800B-10P)
- Zotac Gaming GeForce RTX™ 5080 AMP Extreme Infinity Ultra (ZT-B50800BU-10P)
- Zotac Gaming GeForce RTX™ 5080 Solid (ZT-B50800D-10P)
- Zotac Gaming GeForce RTX™ 5080 Solid OC (ZT-B50800J-10P)
Technical data cooler
Dimensions total (L x W x H)235,60 x 150,57 x 34,10mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Colortransparent
Technical data backplate
Dimensions (L x W x H)235,60 x 122,00 x 6mm
MaterialAluminium
€28.98 *
€20.98 *
€34.98 *
