Alphacool NexXxoS HPE-30 Full Copper 240mm Radiator
  • 14376
  • 4250197143769
  • 0,732 kg
  • 10
€99.98 *
€6.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
12886 Alphacool Eisbaer LT (Solo) - black
€74.98*
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TI HOF with Backplate PHT EOL
€49.99*
€6.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
L x W x H271.5 x 124 x 30 mm (±3 %)
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size120 mm
Possible fan assembly2x one-sided / 4x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density18 FPI
Weight601 g
Warranty: 10 years
€39.98 *
€57.98 *
€1.78 *
Delivery date: in 2 - 3 weeks
