Alphacool NexXxoS HPE-30 Full Copper 140mm Radiator
  • 14470
  • 4250197144704
  • 0,642 kg
  • 10
€89.98 *
12960 Alphacool Eisbaer Aurora (Solo) - Digital RGB
€69.98*
WZS Alphacool Apex filling funnel G1/4"
€8.98*
€16.99*
11948 Eisblock Aurora Acryl GPX-A Radeon RX 6800XT/6900XT Nitro+ with Backplate
€49.98*
€14.98*
15394 Alphacool Core 200 Aurora reservoir D5/VPP Acetal/Acryl
€56.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H173.5 x 144 x 30 mm (±3 %)
Quantity of cooling channels16
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size140 mm
Possible fan assembly1x one-sided / 2x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density18 FPI
Weight496 g
Warranty: 10 years
€39.98 *
€57.98 *
€34.98 *
