Alphacool Eisbaer Aurora LT Solo - Black
- Article no.: 13066
- EAN: 4250197130660
- Weight: 0,734 kg
- Available: Currently there are 8 available
The Eisbaer Aurora LT Solo combines CPU cooling block, reservoir and pump in one product. The low construction height allows flexible use in a wide range of scenarios. Especially in small cases with little space, the Eisbaer Aurora LT Solo can convince. The product is also used as the basis of Alphacool's popular AiO water coolers.
Radiator & Pump
As with all Alphacool products, the radiator base is made of nickel-plated copper and is equipped with very fine cooling fins that are distributed over the entire base. A nozzle plate provides an accelerated flow over the cooling fins which increases the cooling performance. The water flow is optimized so that all areas of the cooler base are cooled evenly. The Eisbaer LT Aurora cooler uses the very compact and small DC-LT 2 pump. It provides enough power to add another component such as a GPU water cooler or another radiator to the circuit.
Full Digital aRGB Illumination
The cooler pump assembly and fans are fully equipped with Digital RGB LEDs, also known as addressable RGB or aRGB. Extensive effects can be set with the included controller or a Digital RGB controller on the motherboard. For a nice visual effect, of course, the illuminated polar bear on the cooler pump unit. For easier control via a controller, the fans and also the pump can be connected in series as a daisy chain. This enables a neat wiring of the individual LED components.
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5 / FM1 / FM2 / FM2+ / SP3 / SP6 / sTRX4 / sWRX8
| Technical data cooler with pump | |
| L x W x H | 69 x 69 x 45 mm |
| Material cooler bottom | nickel plated copper |
| Threads | 2x G 1/4 (+ 1x Fillport G 1/4) |
| Pump type | DC-LT2 |
| Pump speed | 2600 rpm (±10 %) |
| Head of delivery | 1 m |
| Maximum flow | 72 L/h |
| Voltage | 6-13.5 V DC |
| Power consumption | 3.2 W |
| Pressure tested | 0.8 bar |
Delivery date: in 5 - 6 weeks
