Alphacool NexXxoS Monsta 120mm radiator
  • 14180
  • 4250197141802
  • 1,146 kg
€83.98 *
Info about the Monsta radiators:
The Monsta radiators, with a thickness of 80mm, are the first of their size on the market. Hence we were just as keen on finding out how they perform as the independent reviewers!
The tests show that it has significantly increased flow rates than thinner radiators. The cooling performance increased greatly with increased fan speed. Sounds normal, but this radiator shows a different performance profile than standard radiators: At 500rpm the Monsta is slightly better than its 60mm brother, but with increasing fan speed the difference increases: At 800rpm the Monsta already performs much better, and at 1200rpm a Monsta radiator is performing almost as well as a 60mm thick radiator with one fan more, at the same fan speed!
This is truly amazing, and all that at this affordable price!
Cooling channelsCopper
Colorschwarz
Fan threadM3
Number of fans1
Connection6x G1/4"
SlatsCopper
Thickness69 - 100mm
Fan size120mm
HousingSteel
ManufacturerAlphacool
Pressure tested0,8 bar
Fins per inch10
Dimensions (L x W x H)160 x 124 x 86mm
34%
Laing DDC-pump 12V DDC 4.2
€66.99 * €101.13 *
WAC Alphacool Core 1 Silver
€25.98 *
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 60cm weiß
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 60cm white
€5.99 *
€4.97 *
€3.78 *
45%
Content 100 cm² (€0.18 * / 1 cm²)
€17.98 * €32.97 *
48%
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x2mm
€12.88 * €24.98 *
€3.47 *
€2.48 *
€69.98 *
22%
€46.98 * €59.98 *
