Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 60cm white
  • 18730
  • 4250197187305
  • 0,055 kg
  • Currently there are 8 available
€5.99 *
Content: 60 Zentimeter (€9.98 * / 100 Zentimeter)
€5.98*
€12.98*
€16.99*
€15.98*
€18.98*
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and... more
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB. This cable is ideal for expanding the limited number of motherboard slots for these types of fans. With high-quality sleeving, the cable offers added protection, stability, and longer lifetime. The cable is offered in various lengths.
Length60cm
Connections1x 4-Pin to 4x 4-Pin PWM
MaterialPlastic, sleeved
Colorwhite
€1.79 *
€2.28 *
€4.97 *
€2.98 *
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 30cm white
Content 30 Zentimeter (€15.60 * / 100 Zentimeter)
€4.68 *
€3.78 *
Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
€2.58 *
WAC Alphacool Core 1 White
€115.98 *
€6.99 *
€4.48 *
€5.99 *
€1.68 *
€1.48 *
€5.28 *
€4.38 *
€2.68 *
€37.98 *
