  • 18680
  • 4250197186803
  • 0,029 kg
€3.47 *
Content: 30 Zentimeter (€11.57 * / 100 Zentimeter)
€5.98*
€12.98*
€16.99*
€15.98*
€18.98*
*1 Offer valid until 18/11/2026
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and... more
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB. This cable is ideal for expanding the limited number of motherboard slots for these types of fans. With high-quality sleeving, the cable offers added protection, stability, and longer lifetime. The cable is offered in various lengths.
Length30cm
Connections1x 4-Pin to 3x 4-Pin PWM
MaterialPlastic, sleeved
€1.79 *
€2.28 *
€2.68 *
€2.28 *
€2.78 *
€2.68 *
€4.38 *
€1.98 *
€1.48 *
€5.99 *
€2.78 *
€2.48 *
