- Article no.: 18684
- EAN: 4250197186841
- Weight: 0,055 kg
Alphacool's 4-pin to 4x 4-pin Y-splitter cable is a high-quality solution to easily connect and control multiple PWM fans from the motherboard without the need for a separate fan control HUB.This cable is ideal for expanding the limited number of motherboard slots for these types of fans. With high-quality sleeving, the cable offers added protection, stability, and longer lifetime. The cable is offered in various lengths.
| Technical details | |
| Length | 60cm |
| Connections | 1x 4-Pin to 4x 4-Pin PWM |
| Material | Plastic, sleeved |
| Color | black |
