  • 12460
  • 4250197124607
  • 0,072 kg
€86.28 * €119.98 * (28.09% Saved)
Content: 100 cm² (€0.86 * / 1 cm²)
€0.98 *
€1.19 *
32%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.55 * / 1 cm²)
€54.78 * €79.98 *
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x0,5mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.88 * €46.98 *
€2.28 *
€2.78 *
€6.49 * €8.98 *
€6.99 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.01 * / 1 cm²)
€48.48 * €69.98 *
