Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
  • 12458
  • 4250197124584
  • 0,04 kg
€32.88 * €46.98 * (30.01% Saved)
Content: 100 cm² (€0.33 * / 1 cm²)
€0.98 *
€1.19 *
32%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1mm PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
Content 100 cm² (€0.55 * / 1 cm²)
€54.78 * €79.98 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 15cm
€2.48 *
€2.28 *
€2.78 *
€1.89 *
€6.49 * €8.98 *
WÄM Alphacool Wärmeleitklebepad doppelseitig 26x30x0,5mm
Alphacool thermal adhesive pad double-sided 26x30x0.5mm
Content 7.8 cm² (€0.14 * / 1 cm²)
€1.09 *
€6.99 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.01 * / 1 cm²)
€48.48 * €69.98 *
