Alphacool Core 120mm fan PWM 4000rpm (120x120x25mm)
  • 24845
  • 4250197135870
  • 0,162 kg
€10.98 *
RAB Alphacool Shroud & Decoupling 120mm (7mm thick) incl. 4x M3x37mm screws
€5.48*
26158 Alphacool ES Guardian 4Port Powerfan Hub
€52.98*
LZ Alphacool Susurro Antinoise Silicone Fan Frame - 120mm - universal EOL
€3.97*
Alphacool's Core 120mm is a quiet and efficient fan with a wide control range up to 4000 rpm.... more
Alphacool's Core 120mm is a quiet and efficient fan with a wide control range up to 4000 rpm. The PWM controllable fan is not only suitable as a fan on CPU coolers or radiators. Due to its excellent performance values (throughput & static pressure), it can also be used as a case fan. The double-bearing fan axis is smooth running and enables a long service life as well as quiet operation. If you are looking for a powerful fan without aRGB illumination, you will find it in Alpacool's Core 120mm model!
Connections
The fan is controlled via a 4-pin PWM connector. The cable is 40cm long. This allows the fan to be connected directly to the motherboard or a dedicated controller without the use of additional adapter cables or extensions.
Control range
The fan can be controlled from 0 to 4000 rpm via the 4-pin PWM connector. At maximum speed, it allows an airflow of 119.8 CFM combined with a high static pressure of 12.67 mm/H2O. This makes the fan perfect for mounting on radiators of a water cooling system or for ventilating a case.
Dimension (L x W x H)120 x 120 x 25 mm
Materialsynthetic material (PBT UL94V-0)
Bearing TypeTwo Ball Bearing
Rated VoltageDC 12 V
Operating VoltageDC 7-14 V
Start-up Voltage7 V
Rated Current0.53 (Max: 0.67) A
Rated Power6.36 (Max: 8.04) W
Rated Speed0-4000 rpm ±10 %
Max. Air Flow119.8 CFM
Max. Static Pressure12.67 mmH₂O
Noise level49.5 (Max: 51.5) dBA
Life Expectance70 000 h at 40 °C
Connection4-Pin PWM
Speed Control Modevia PWM
Operating Temperature-10 to +70 °C
Other FeaturesTachometer Output, Auto Start, Soft Start, Waterproof Level IP22
€3.47 *
Delivery date: in 5 - 6 weeks
€39.98 *
€2.78 *
€2.48 *
€1.98 *
€6.49 * €8.98 *
