Alphacool Core Geforce RTX 5080 ROG Astral with Backplate
- Article no.: 10267
- EAN: 4250197102674
- Weight: 1,779 kg
- Asus ROG Astral GeForce RTX™ 5080 16GB GDDR7 OC Edition
| Technical data cooler | |
| Dimensions total (L x W x H) | 261,00 x 161,20 x 34,15mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 11 |
| Color | transparent |
| Dimensions (L x W x H) | 261,00 x 132,70 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
