Alphacool Eisdecke DDC Acrylic Top V.4
  • 13317
  • 4250197133173
  • 0,287 kg
€41.98 *
13179 Alphacool Laing DDC310 - Single Edition - black
€69.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
LED Alphacool Aurora LED RGB connector 90° - Black EOL
€1.18*
13996 Laing DDC-pump 12V DDC 4.2 PWM
€74.98*
Quiet, powerful and spectacular! The Alphacool ice cover is the perfect attachment to take your... more
Quiet, powerful and spectacular! The Alphacool ice cover is the perfect attachment to take your pump to the next stage.
Maximum flow rate
Make your Alphacool DC-LT, Laing DDC, Eispumpe VPP755 or Laing D5 pump first class with this attachment! Thanks to the many 1/4" threads, the Alphacool Eisdecke is the universal companion for every pump. With the dual attachment you can even connect two pumps in series and thus maximize the performance of your water cooling.
Optimal comfort
Alphacool gives you the flexibility you need. No matter how you place your pump in your system, there are no limits to the Alphacool Eisdecke. So you can choose whether you want to mount your pump standing up, lying down, at a 45° or 90° angle. The included feet give you the greatest possible variety of mounting options for your case.
Unlimited color spectrum
The absolutely clear acrylic glass with pre-assembled RGB strip makes the Alphacool Eisdecke Plexi look like a diamond. The 4-pin male RGB connector makes your top compatible with the most common controllers. The new, patented locking screws in an ultra-flat design fit perfectly into the Eisdecke.
Silent - in the highest quality
The Alphacool Eisdecke can be equipped with vibration dampers that make your pump quieter than ever before. Nothing will disturb the performance you need.
  • Dimensions: 62 x 62 x 25 mm
  • Height with feet: 91 mm
  • Material: Acrylic, aluminum feet
  • Connections: 3x ¼“ in-thread and 3x ¼“ out-thread
  • Compatibility: Alphacool Laing DDC310, Laing DDC (all versions)
Scope of delivery
  • 4x G ¼“ closures
  • 2x feet
  • 8x M4 x6 screws
  • 4x M4 nut
  • 4x M4 decouplings
  • 4x M4 x25 screws
Datasheet
52%
€29.98 *
WAO Alphacool MCX ram
Alphacool MCX ram
€0.99 *
€5.99 *
€2.98 *
€33.98 *
