Alphacool Apex Fillport - chrome
  • 13467
  • 4250197134675
  • 0,054 kg
€15.68 *
WZS Alphacool pumpin gum ball - black
€10.98*
€36.98*
WZS Alphacool Apex filling funnel G1/4"
€8.98*
€14.98*
14466 Alphacool Filling bottle Core 500ml
€5.99*
A simple but effective port for easy filling of a water loop. The flat design makes it... more
A simple but effective port for easy filling of a water loop. The flat design makes it unobtrusive, so it fits in with most cases and blends into the overall look without being disruptive. The included stop plug screws in almost all the way, so it closes almost flush. Therefore, you get a port with the Alphacool Apex Fillport that doesn't protrude and looks like it belongs to the case instead of being retrofitted.
Material
The fillport and the included nut are made of solid chrome-plated brass, making them very sturdy. The chome coating is durable and firmly bonded to the surface, preventing scratches or chipping.
Mounting
To mount, drill a 20mm diameter hole anywhere in the case. The fillport is inserted and screwed tightly and securely with the enclosed nut. Please note that the fillport should be the highest point in the water cooling system.
G1/4" Connections
L x W x H42 x 30 x 15 mm
Materialbrass
Colorchrome
ConnectionG 1/4 IT
Thread for case mountingM20
Weight51 g
€37.98 *
