  • 17555
  • 4250197175555
  • 0,048 kg
€16.98 * €17.98 * (5.56% Saved)
17350 Alphacool Eisfluegel flow indicator G1/4 square - acetal
€18.98*
€18.98*
17464 Alphacool Eisfluegel Aurora flow indicator "HighFlow" with RPM-Signal
€38.98*
ANS Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Deep Black
€7.48*
29142 Alphacool Eiszapfen Acryl/Acetal Inline filter G1/4 inner thread
€12.98*
The Alphacool temperature sensor Square Acetal is a simple cube-shaped water temperature sensor... more
The Alphacool temperature sensor Square Acetal is a simple cube-shaped water temperature sensor that can be easily integrated into any water circuit.
Integration made easy
The temperature sensor is very compact and can be integrated into any water circuit thanks to its two G1/4" internal threads. It does not matter whether the system is equipped with hoses or hard tubes. The corresponding connections are simply screwed onto the sensor and then mounted at any position in the water circuit. By using acetal, the temperature sensor is extremely light at just 29g.
sensor
A classic NTC 10 kOhm sensor is used as the sensor. The readable temperature range is between -40 and 125°C. The cable is 40 cm long and ends in a typical 2-pin connector. Many mainboards now offer direct connection options for such sensors. Please check the manual for your mainboard. There are of course also various external controllers that offer a connection for the sensor.
design
The new square design stands out from the usual, mostly round, sensors. Alphacool avoids large logo placements. The product should be in the foreground. The square design fits perfectly with the new Alphacool Eisblock graphics card water cooler series.
L x W x H: 26.5 x 26.5 x 26.5 mm
Sensor: NTC 10 kOhm
Measuring range: -40 to 125°C
Connector: 2-pin
Cable length: 40 cm
Thread: 2x G1/4"
Download data sheet PDF: Alphacool temperature sensor Square Acetal
€1.78 *
