  • 12456
  • 4250197124560
  • 0,031 kg
€14.38 * €21.98 * (34.58% Saved)
Content: 48 cm² (€0.30 * / 1 cm²)
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1,5mm - 2 Stück PHT EOL
Content 48 cm² (€0.41 * / 1 cm²)
€19.88 * €28.98 *
61%
€5.78 * €14.98 *
€6.49 * €8.98 *
29%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x0,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
Content 48 cm² (€0.45 * / 1 cm²)
€21.38 * €29.98 *
31%
€23.98 * €34.97 *
€34.98 *
43%
€3.97 * €6.99 *
6%
€16.98 * €17.98 *
€6.99 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
€28.98 *
