Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x0.5mm - 2 pieces
  • 12461
  • 4250197124614
  • 0,033 kg
€21.38 * €29.98 * (28.69% Saved)
Content: 48 cm² (€0.45 * / 1 cm²)
31%
€23.98 * €34.97 *
Content 100 cm² (€0.86 * / 1 cm²)
€86.28 * €119.98 *
35%
WÄM Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück PHT EOL
Content 48 cm² (€0.30 * / 1 cm²)
€14.38 * €21.98 *
47%
€15.78 * €29.98 *
33%
€5.99 * €8.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
€2.68 *
43%
€3.97 * €6.99 *
€6.49 * €8.98 *
31%
WÄM Alphacool Eisschicht Wärmeleitpad - 14W/mK 120x20x1,5mm - 2 Stück PHT EOL
Alphacool Ice Layer Thermal Pad - 14W/mK 120x20x1.5mm - 2 pieces
Content 48 cm² (€1.01 * / 1 cm²)
€48.48 * €69.98 *
Alphacool D-RAM module (for Alphacool D-RAM cooler) - black 2 pieces
Content 2 Stück (€11.99 * / 1 Stück)
€23.98 *
