Alphacool Dual 24-pin power supply starter cable (2x24-pin to 1x24-pin)
- Article no.: 18732
- EAN: 4250197187329
- Weight: 0,074 kg
*1Alphacool's Dual 24-pin Power Supply Starter Cable allows for the parallel starting of two power supplies through the motherboard. This allows for an additional power supply with its own power circuit to be added to the system. This is particularly advantageous in systems with multiple graphics cards. Using the Dual Starter Cable, both power supplies start simultaneously.
| Technical data | |
| Cable length | 10cm |
| Cable length (starter cable) | 20cm |
| Connection | 24-Pin ATX (2x24-pin to 1x24-pin) |
| Material | Plastic |
| Weight | 72g |
| Color | black |
