Alphacool Core Geforce RTX 5080 Aorus Master + Windforce with Backplate
  • 10290
  • 4250197102902
  • 1,441 kg
€219.98 *
€37.98*
€35.98*
€125.98*
- Gigabyte GeForce RTX™ 5070 Ti AERO OC 16G (GV-N507TAERO OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti GAMING OC 16G (GV-N507TGAMING OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti WINDFORCE OC SFF 16G (GV-N507TWF3OC-16GD)
- Gigabyte GeForce RTX™ 5070 Ti WINDFORCE SFF 16G (GV-N507TWF3-16GD)
- Gigabyte AORUS GeForce RTX™ 5080 MASTER 16G (GV-N5080AORUS M-16GD)
- Gigabyte GeForce RTX™ 5080 AERO OC SFF 16G (GV-N5080AERO OC-16GD)
- Gigabyte GeForce RTX™ 5080 GAMING OC 16G (GV-N5080GAMING OC-16GD)
- Gigabyte GeForce RTX™ 5080 WINDFORCE OC SFF 16G (GV-N5080WF3OC-16GD)
- Gigabyte GeForce RTX™ 5080 WINDFORCE SFF 16G (GV-N5080WF3-16GD)
Technical data cooler
Dimensions total (L x W x H)205,50x 140,93 x 34,19mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs8
Colortransparent
Technical data backplate
Dimensions (L x W x H)205,50 x 112,40 x 6mm
MaterialAluminium
Delivery date: in 6 - 7 weeks
€28.98 *
Alphacool HardTube 16/13mm 90° acrylic (PMMA) 10/30cm
Content 40 Zentimeter (€24.95 * / 100 Zentimeter)
€6.49 * €8.98 *
