Alphacool Mini USB to Mainboard USB 5-Pin 40cm
- Article no.: 18717
- EAN: 4250197187176
- Weight: 0,015 kg
€2.98 *
Content:
40 Zentimeter
(€7.45 *
/ 100 Zentimeter)
High quality Mini USB to motherboard USB 5-pin cable with 40cm length for connecting electronic... more
High quality Mini USB to motherboard USB 5-pin cable with 40cm length for connecting electronic components. For example for mounting USB devices inside the case like fans/RGB controllers.
| Technical data | |
| Length | 40cm |
| Connections | Mini USB to mainboard USB 5-pin |
| Weight | 11g |
| Color | black |
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
Content
60 Zentimeter
(€4.97 * / 100 Zentimeter)
€2.98
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content
30 Zentimeter
(€3.30 * / 100 Zentimeter)
€0.99
Alphacool Ice Matrix connection cable - 10cm
Content
10 Zentimeter
(€9.90 * / 100 Zentimeter)
€0.99
Content
30 Zentimeter
(€19.97 * / 100 Zentimeter)
€5.99
Content
30 Zentimeter
(€7.60 * / 100 Zentimeter)
€2.28
Content
6 Stück
(€2.50 * / 1 Stück)
€14.98
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content
4 Stück
(€7.00 * / 1 Stück)
€27.98
Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
€41.98
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV White 1m (3ft) Retailbox
Content
100 Zentimeter
€7.98
Content
300 Zentimeter
(€4.99 * / 100 Zentimeter)
€14.98
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
Content
330 Zentimeter
(€0.60 * / 100 Zentimeter)
€1.98
€4.47
5%
flow cooler Hailea Ultra Titan 300 (HC250=265Watt cooling capacity) - White Special Edition
€389.97
€411.99
