WAK Alphacool Core Geforce RTX 5090 Gamerock + Phantom with backplate
  • 10259
  • 4250197102599
  • 1,779 kg
€219.98 *
€19.98*
€37.98*
€125.98*
€35.98*
- Gainward GeForce RTX™ 5090 Phantom (4878 / NE75090019R5-GB2020P)
- Gainward GeForce RTX™ 5090 Phantom GS (4861 / NE75090S19R5-GB2020P)
- Palit GeForce RTX™ 5090 GameRock (NE75090019R5-GB2020G)
- Palit GeForce RTX™ 5090 GameRock OC (NE75090S19R5-GB2020G)
Technical data cooler
Dimensions total (L x W x H)214,40 x 153,37 x 34,38mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs9
Colortransparent
Technical data backplate
Dimensions (L x W x H)214,40 x 124,80 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€28.98 *
WAC Alphacool Core 1 White
€115.98 *
WAC Alphacool Core 1 Silver
€2.28 *
€27.98 *
€6.49 * €8.98 *
