Alphacool Core Geforce RTX 5090 TUF Gaming with backplate
  • 10269
  • 4250197102698
  • 1,891 kg
€229.98 *
€19.98*
€37.98*
€125.98*
€35.98*
- Asus TUF Gaming GeForce RTX™ 5090 32GB GDDR7 (90YV0LY1-M0NA00)
- Asus TUF Gaming GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LY0-M0NA00)
Technical data cooler
Dimensions total (L x W x H)235,95 x 155,57 x 34,12mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs9
Colortransparent
Technical data backplate
Dimensions (L x W x H)235,95 x 127,00 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
€34.98 *
Alphacool Eiszapfen 16/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
Delivery date: in 7 - 8 weeks
