Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
  • 13485
  • 4250197134859
  • 0,027 kg
€33.88 * €49.98 * (32.21% Saved)
Content: 24 cm² (€1.41 * / 1 cm²)
€4.28*
€69.98*
13484 Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1,5mm
€75.68*
Alphacool offers a wide range of thermal pads for effective heat dissipation of electric... more
Powerful!
Increased lifespan!
Versatile!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 1,5mm
Thermal Conductivity (ASTM D5470)17.8 W/mK (±10%)
Hardness (ASTM D2240)65 (Shore 00) (±5)
Working temperature-50 to ~150°C
Volume Resistance (ASTM D257)6×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)4 KV/mm (±10%)
Density (ASTM D792)3.5 g/cm³ (±10%)
Elongation (ASTM D412)20%
Flame Rating (UL 94)V-0
Colorlight grey
41%
WÄM Alphacool Apex Wärmeleitpad Soft 18W/mk 120x20x1mm
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1mm
Content 24 cm² (€0.98 * / 1 cm²)
€23.59 * €39.98 *
56%
Alphacool Apex Thermal Pad Soft 18W/mk 100x100x1mm
Content 100 cm² (€0.44 * / 1 cm²)
€43.98 * €99.98 *
41%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x3mm
Content 16 cm² (€0.48 * / 1 cm²)
€7.68 * €12.98 *
38%
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.39 * / 1 cm²)
€6.18 * €9.98 *
45%
Alphacool Core Thermal Pad Soft 9W/mk 100x100x1,5mm
€16.48 * €29.98 *
€3.47 *
€1.68 *
€5.28 *
33%
€5.99 * €8.98 *
21%
€33.97 * €42.98 *
€41.98 *
€6.99 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
