Alphacool Core Geforce RTX 5080 Gamerock + Phantom with backplate
  • 10260
  • 4250197102605
  • 1,529 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- Gainward GeForce RTX™ 5070 Ti Phantom (NE7507T019T2-GB2030P)
- Palit GeForce RTX™ 5070 Ti GameRock (NE7507T019T2-GB2030G)
- Palit GeForce RTX™ 5070 Ti GameRock OC (NE7507TH19T2-GB2030G)
- Gainward GeForce RTX™ 5080 Phantom (4915 / NE75080019T2-GB2030P)
- Gainward GeForce RTX™ 5080 Phantom GS (4908 / NE75080T19T2-GB2030P)
- Palit GeForce RTX™ 5080 GameRock (NE75080019T2-GB2030G)
- Palit GeForce RTX™ 5080 GameRock OC (NE75080T19T2-GB2030G)
Technical data cooler
Dimensions total (L x W x H)173,50 x 154,03 x 34,07mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs8
Colortransparent
Technical data backplate
Dimensions (L x W x H)173,50 x 154,03 x 6mm
MaterialAluminium
Delivery date: in 6 - 7 weeks
€28.98 *
WAC Alphacool ES 1 1U
Alphacool ES 1 1U
€132.98 *
32%
Alphacool Apex Thermal Pad Soft 18W/mk 120x20x1,5mm
Content 24 cm² (€1.41 * / 1 cm²)
€33.88 * €49.98 *
WAC Alphacool Core 1 White
€115.98 *
WAC Alphacool Core 1 Silver
