Alphacool Core Geforce RTX 5070 Reference with Backplate
  • 10271
  • 4250197102711
  • 1,216 kg
€219.98 *
€19.98*
€37.98*
€35.98*
13886 Alphacool Core 1 LT Aurora Acrylic
€84.98*
- Inno3D GeForce RTX™ 5070 TWIN X2 (N50702-12D7-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC (N50702-12D7X-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC WHITE (N50702-12D7X-195064W)
- Inno3D GeForce RTX™ 5070 X3 OC (N50703-12D7X-195064L)
- MSI GeForce RTX™ 5070 12G INSPIRE 3X OC (G5070-12I3C)
- MSI GeForce RTX™ 5070 12G SHADOW 2X OC (G5070-V532 V1.1)
- MSI GeForce RTX™ 5070 12G VENTUS 2X OC (G5070-12V2C)
Technical data cooler
Dimensions total (L x W x H)149,00 x 124,07 x 34,12mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs6
Colortransparent
Technical data backplate
Dimensions (L x W x H)149,00 x 95,50 x 6,00mm
MaterialAluminium
52%
Hint!
€4.80 * €9.98 *
€6.49 * €8.98 *
€25.98 *
€37.98 *
€25.98 *
WAC Alphacool ES 1 1U
Alphacool ES 1 1U
€132.98 *
€33.98 *
€1.89 *
20%
€3.97 * €4.97 *
Alphacool fan radiator screw M3 x 15 mm - 4 pieces
€3.48 *
