Alphacool Core Geforce RTX 5080 Prime with Backplate
  • 14763
  • 4250197147637
  • 1,554 kg
€219.98 *
€37.98*
€35.98*
€125.98*
- Asus Prime GeForce RTX 5070 Ti OC, PRIME-RTX5070TI-O16G, 16GB GDDR7 (90YV0MF0-M0NA00)
- Asus Prime GeForce RTX 5080 OC, PRIME-RTX5080-O16G, 16GB GDDR7 (90YV0LX0-M0NA00)
- Asus Prime GeForce RTX 5080, PRIME-RTX5080-16G, 16GB GDDR7
Technical data cooler
Dimensions total (L x W x H)220x 140,60 x 34,19mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs10
Colortransparent
Technical data backplate
Dimensions (L x W x H)220 x 112,10 x 6mm
MaterialAluminium
Delivery date: in 5 - 6 weeks
€28.98 *
€69.98 *
