  • 5100117
  • 4070201001171
  • 0,307 kg
  • 10
Content: 3.3 Laufende(r) Meter (€4.24 * / 1 Laufende(r) Meter)
17228 Alphacool Eiszapfen 13/10mm compression fitting G1/4 - deep black sixpack
€35.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle 90° rotatable G1/4 - Deep Black
€8.98*
SZ Alphacool hose cutter aluminum 3-19mm
€18.98*
The EPDM tube from Alphacool's Enterprise Solutions series is characterized by its high... more
The EPDM tube from Alphacool's Enterprise Solutions series is characterized by its high resistance to acids, bases and external influences and has an exceptional durability compared to conventional PVC tubes. The matt black tube with its subtle velvet look quickly becomes an eye-catcher in every water-cooled PC.
What is the advantage of EPDM?
Compared to standard PVC hoses, the EPDM tube from Alphacool is significantly more temperature-resistant and allows working temperatures well above 100 °C. Even at higher water temperatures, the EPDM tube remains dimensionally stable and prevents the hose from warping in places with tighter bending radii or connections. The risk of the water circuit leaking or the water flow being obstructed is therefore eliminated. The high resistance to external influences makes the Alphacool EPDM hose extremely durable and long-lasting.
Assembly
The Alphacool EPDM Tube is slightly more dimensionally stable than a PVC hose. Nevertheless, it has excellent bendability and flexibility for effortless installation even with tighter bending radii.
Connections
The EPDM hose can be used with all hose connectors (in the appropriate size) from Alphacool's Eiszapfen or HF series.
Technical Data
Lenght3,3m
MaterialEthylene-propylene-diene rubber (EPDM, without talc)
Hose size13mm OD / 10mm ID (Tolerances according to DIN ISO 33-02-1 E1)
Hardness80° (± 5°) Shore A
Working temperature-35°C to +120°C
ColorMatt Black
Warranty: 10 years
Delivery date: in 5 - 6 weeks
€27.98 *
