Alphacool Aurora XPX Digital RGB Frame - Black
  • 12942
  • 4250197129428
  • 0,034 kg
€6.99 *
KAB Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm EOL
€1.98*
€15.98*
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
€24.48*
It's finally here! The new Alphacool Aurora XPX Frame with addressable RGB. Perfect for your XPX... more
It's finally here! The new Alphacool Aurora XPX Frame with addressable RGB. Perfect for your XPX CPU cooler.
Optics at its finest
The new XPX Frame with aRGB technology has additional color options to illuminate your entire system with different color modes. This makes your gaming system a real eye-catcher at every LAN party or simply at home. Every XPX Plexi CPU water cooler shines in unexpected, bright colors.
Alphacool offers compatibility
With the new XPX Frame from Alphacool you can illuminate all XPX Plexi or Satin coolers and thus equip a variety of different systems, just as you want. The frame is simply pushed over your CPU cooler and fixed in place. Your modding computer is ready. The power connection is via a 3-pin digital RGB connector, which is connected to your controller or directly to the mainboard. Alphacool offers the Eiscontrol Addressable RGB Controller for this purpose, suitable for all digital RGB products. Alphacool products are compatible with Asus Aura Sync, Gigabyte RGB Fusion 2.0 and many other hardware manufacturers.
Technical data:
  • Dimensions: 75 x 75 x 17 mm
  • Cable length: 72 cm
  • Connector: 3-pin
  • Material: POM
  • LEDs: 15 x Digitally Addressable RGB LEDs
62%
€0.99 * €2.59 *
€6.49 * €8.98 *
€37.98 *
€25.98 *
