Alphacool Eiswand 360 CPU - black
  • 11026
  • 4250197110266
  • 11,72 kg
€439.98 *
ANK Alphacool Eiszapfen quick release coupling set with double bulkhead screw connection G1/4 IG - chrome
€33.98*
ANK Alphacool Eiszapfen quick release coupling set with double bulkhead screw connection G1/4 IG - Deep
€33.98*
12879 Alphacool Eisfrost Xtreme liquid metall paste 1g
€6.99*
WZS filling aid - plastic funnel
€4.99*
The Eiswand is Alphacool’s complete water cooling set for your CPU. Thanks to the included... more
Thanks to the included quick-release connectors, it’s easy to connect additional components to the loop, such as the Eiswolf, Alphacool’s pre-filled graphics card cooler, or an additional radiator. Finding a fitting graphics card cooler is easy with the configurator at www.Alphacool.com
The core component of the Eiswand is the external 360mm full-copper radiator, which is equipped with six Eiswind fans. This means the system’s cooling power is very high, enough for any combination of CPU and GPU. Copper offers double the heat capacity of the aluminium often used in cheap systems. The six Eiswind fans are built to operate in Push&Pull configuration, to guarantee optimal radiator ventilation.
The illuminated reservoir sits directly on the external radiator. There, the fill level can easily be checked through the large viewing window, and the fill port on the upper surface makes it easy to fill the loop.
The elegant, likewise illuminated bottom of the Eiswand contains two DC-LT silent pumps, which are also used in several of Alphacool’s other systems. For example, they are used in the Alphacool Eisbaer, often praised for its low noise level. The pumps’ capacity is so high that even if one of them fails, there is no noticeable loss of cooling power. One pump is strong enough to keep a simple cooling loop going. This guarantees top-level security for your whole system.
The included XP3 cooler is among the strongest coolers on the market and is compatible with all Intel and AMD sockets. Of course, the set also includes all the other necessary parts, such as a 11/8mm 4m-long hose, corresponding connectors, and the required coolant.
The Alphacool Eiswand gives you an all-around carefree package for your system.
Intel 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066 / 1851
AMD AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ / AM4 / AM5 / TR4 / sTRX4 / sWRX / SP3
L x W x H Eiswand210 x 155 x 534 mm
360mm XT45 full-copper radiator1x
Eiswind fans 1100/700 RPM6x
XP3 CPU cooler1x
external power supply1x
11mm Anti-kink springs4x
11/8mm tubing4m
11/8mm straight connectors G 1/4"4x
Quick-release connectors2x
1L Tec Protect 22x
€6.99 *
21%
SZ Schlauchabschneider
hose cutter
€4.97 * €6.30 *
LK Alphacool Y-Splitter 4-Pin auf 4x 4-Pin PWM 60cm weiß
Alphacool y-splitter 4-Pin to 4x 4-Pin PWM 60cm white
€5.99 *
WAC Alphacool Core 1 White
€115.98 *
€2.78 *
