  • 24767
  • 4250197247672
  • 0,003 kg
€0.99 * €5.02 * (80.28% Saved)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
  • Material: aluminum
  • Variant: X4 Flat
  • Dimensions: 19 x 55 x 2.5mm
  • Color: Black
Scope of delivery
  • Alphacool Eiskamm Alu X4 Flat - 4mm black - 4 pieces
Datasheet
Assembly instructions
€0.99 * €5.02 *
€0.99 * €5.02 *
86%
€0.99 * €6.96 *
90%
€0.99 * €9.94 *
88%
€0.99 * €8.00 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - White (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
€0.99 * €5.02 *
€0.99 * €5.02 *
83%
KAB Alphacool Eiskamm Alu X6 - 4mm black - 4 Stück PHT EOL
Alphacool Eiskamm Alu X6 - 4mm black - 4 pieces
€0.99 * €5.94 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm red - 4 pieces
€0.99 * €4.59 *
€0.99 * €4.89 *
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
89%
Alphacool Eiskamm Alu X14 - 4mm black - 4 pieces
€0.99 * €9.02 *
€0.99 * €5.02 *
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
Phobya VGA Power Connector 6+2Pin plug incl. 8 pins - 2 pieces Black
Content 2 Stück (€1.44 * / 1 Stück)
€2.87 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Neon Green (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Acid Purple (Paracord 550 Typ 3) 330cm EOL
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Acid Purple (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
Alphacool Eiskamm Alu X5 Flat - 4mm red - 4 pieces
€0.99 * €4.89 *
Alphacool Eiskamm Alu X4 - 4mm red - 4 pieces
€0.99 * €4.89 *
€0.99 * €5.02 *
90%
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
€0.99 * €9.94 *
86%
Alphacool Eiskamm Alu X8 - 4mm silver - 4 pieces
€0.99 * €6.96 *
75%
€0.99 * €3.99 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
€2.58 *
