Alphacool Core XT45 Full Copper 240mm Radiator
  • 13768
  • 4250197137683
  • 1,568 kg
  • 10
€157.98 *
18439 Alphacool HardTube 13/10mm Acryl clear 60cm - 4pcs
€15.98*
ANS Alphacool Eiszapfen 13/10mm screw-on nozzle G1/4 - Chrome
€6.98*
13446 Alphacool Core 1 Aurora Black
€125.98*
14672 Alphacool Core Distroplate 240 XS D5/DDC
€209.98*
For more than a decade, Alphacool’s Full Copper Radiator Series has set the standard in liquid... more
For more than a decade, Alphacool’s Full Copper Radiator Series has set the standard in liquid cooling performance. Now, Alphacool introduces the first radiator in its Core Series – the Core XT45 Full Copper Radiator. It delivers outstanding cooling performance paired with an elegant, modern aesthetic. The clean contours of the redesigned housing are enhanced by interchangeable side panels – available either with discreet integrated aRGB lighting or in a classic, unlit version.
As with Alphacool’s proven NexXxoS models, all water-bearing components of the Core XT45 Radiator – including the fins, channels, and chambers – are made entirely of copper, ensuring excellent thermal conductivity. Inside, an optimized structure delivers noticeably improved cooling performance: sixteen instead of twelve water channels provide better flow dynamics, while the refined fin design further enhances heat transfer.
The radiator features two G1/4" ports designed in Alphacool’s characteristic Core style. Made from high-quality brass and precisely integrated into the end chamber, they combine durability with a clean appearance. A fill and vent port on the opposite side simplifies maintenance by allowing easy filling and draining of the cooling loop.
Each Core XT45 Radiator comes with two interchangeable side panels – one featuring integrated aRGB lighting and one without. Thanks to magnetic mounting, both versions can be swapped effortlessly and without tools. The aRGB version adds a striking visual accent, making the Core XT45 Full Copper Radiator a true centerpiece in any cooling setup.
Technical data radiator
L x W x H297,00 x 133,40 x 50,00mm (+/- 0,25mm)
Quantity of cooling channels32
Material threadsbrass
Material outer housingaluminum
Threads2x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length)
Possible fan size120mm
Possible fan assembly2x one-sided / 4x both-sided
Thread size fan mountingM3
Pressure tested0,8 Bar
Fin density16 FPI
Panelmagnetic,changeable, 1xRGB & 1x non-RGB
aRGByes
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs11
Weight1294g
Warranty: 10 years
38%
KOI Alphacool Core Ocean T38 AIO 280mm
€47.98 * €76.98 *
€41.98 * €59.98 *
Alphacool Eiskamm Alu X5 Flat - 4mm red - 4 pieces
€0.99 * €4.89 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm red - 4 pieces
€0.99 * €4.59 *
89%
Alphacool Eiskamm Alu X14 - 4mm red - 4 pieces
€0.99 * €8.89 *
Alphacool Eiskamm Alu X4 - 4mm red - 4 pieces
€0.99 * €4.89 *
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
€0.99 * €5.02 *
85%
€0.99 * €6.56 *
