Alphacool Core XT45 Full Copper 360mm Radiator
- Article no.: 14584
- EAN: 4250197145848
- Weight: 2,07 kg
For more than a decade, Alphacool’s Full Copper Radiator Series has set the standard in liquid cooling performance. Now, Alphacool introduces the first radiator in its Core Series – the Core XT45 Full Copper Radiator. It delivers outstanding cooling performance paired with an elegant, modern aesthetic. The clean contours of the redesigned housing are enhanced by interchangeable side panels – available either with discreet integrated aRGB lighting or in a classic, unlit version.
As with Alphacool’s proven NexXxoS models, all water-bearing components of the Core XT45 Radiator – including the fins, channels, and chambers – are made entirely of copper, ensuring excellent thermal conductivity. Inside, an optimized structure delivers noticeably improved cooling performance: sixteen instead of twelve water channels provide better flow dynamics, while the refined fin design further enhances heat transfer.
The radiator features two G1/4" ports designed in Alphacool’s characteristic Core style. Made from high-quality brass and precisely integrated into the end chamber, they combine durability with a clean appearance. A fill and vent port on the opposite side simplifies maintenance by allowing easy filling and draining of the cooling loop.
Each Core XT45 Radiator comes with two interchangeable side panels – one featuring integrated aRGB lighting and one without. Thanks to magnetic mounting, both versions can be swapped effortlessly and without tools. The aRGB version adds a striking visual accent, making the Core XT45 Full Copper Radiator a true centerpiece in any cooling setup.
| Technical data | |
| L x W x H | 417,00 x 133,40 x 50,00mm (+/- 0,25mm) |
| Quantity of cooling channels | 32 |
| Material threads | brass |
| Material outer housing | aluminum |
| Threads | 2x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length) |
| Possible fan size | 120mm |
| Possible fan assembly | 3x one-sided / 6x both-sided |
| Pressure tested | 0.8 Bar |
| Fin density | 16 FPI |
| Panel | magnetic,changeable, 1xRGB & 1x non-RGB |
| aRGB | yes |
| Number of digital aRGB LEDs | 18 |
| Weight | 1665g |
| Color | black |
Warranty: 10 years
