Alphacool NexXxoS Monsta 360mm radiator
  • 14182
  • 4250197141826
  • 2,194 kg
€165.98 *
Info about the Monsta radiators:
The Monsta radiators, with a thickness of 80mm, are the first of their size on the market. Hence we were just as keen on finding out how they perform as the independent reviewers!
The tests show that it has significantly increased flow rates than thinner radiators. The cooling performance increased greatly with increased fan speed. Sounds normal, but this radiator shows a different performance profile than standard radiators: At 500rpm the Monsta is slightly better than its 60mm brother, but with increasing fan speed the difference increases: At 800rpm the Monsta already performs much better, and at 1200rpm a Monsta radiator is performing almost as well as a 60mm thick radiator with one fan more, at the same fan speed!
This is truly amazing, and all that at this affordable price!
Abmessungen (L x B x H)400 x 124 x 86mm
Cooling channelsCopper
Fan threadM3
Number of fans3
Connection6x G1/4"
SlatsCopper
Thickness69 - 100mm
Fan size120mm
HousingSteel
ManufacturerAlphacool
Pressure tested0,8 bar
Fins per inch10
€29.98 *
