Alphacool Eiskamm Alu X5 Flat - 4mm red - 4 pieces
  • 24786
  • 4250197247863
  • 0,003 kg
€0.99 * €4.89 * (79.75% Saved)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
The Alphacool Eiskamm Alu is the optimal solution for laying your cables neatly and maintaining the best appearance. The Eiskamm cut from aluminum tubes are much more stable than acrylic versions. To avoid damage to the sleeve, all edges are rounded. Sharp edges that could cut into the sleeve are now a thing of the past. Of course, Alphacool offers all sizes for every cable type, from SATA cables to 8-pin and 24-pin ATX cables, including different colors.
  • Material: aluminum
  • Variant: X5 Flat
  • Dimensions: 23.4 x 5.7 x 2.5mm
  • Color: Red
Scope of delivery
  • Alphacool Eiskamm Alu X5 Flat - 4mm red - 4 pieces
Datasheet
Assembly instructions
€0.99 * €4.89 *
89%
Alphacool Eiskamm Alu X14 - 4mm red - 4 pieces
€0.99 * €8.89 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm red - 4 pieces
€0.99 * €4.59 *
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
85%
€0.99 * €6.56 *
€0.99 * €5.02 *
€0.99 * €5.02 *
42%
Hint!
€25.98 *
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Imperial Red (Paracord 550 Type 3) 330cm
€1.98 *
Alphacool Eiskamm Alu X4 - 4mm red - 4 pieces
€0.99 * €4.89 *
€0.99 * €5.02 *
