  • 24760
  • 4250197247603
  • 0,003 kg
€0.99 * €5.02 * (80.28% Saved)
What is that?
Highlights
  • Made of aluminum
  • More stable than acrylic
  • For all common cable types
  • Four different colors
The Alphacool Eiskamm Alu is the optimal solution for laying your cables neatly and maintaining the best appearance. The Eiskamm cut from aluminum tubes are much more stable than acrylic versions. To avoid damage to the sleeve, all edges are rounded. Sharp edges that could cut into the sleeve are now a thing of the past. Of course, Alphacool offers all sizes for every cable type, from SATA cables to 8-pin and 24-pin ATX cables, including different colors.
  • Material: aluminum
  • Variant: X4
  • Dimensions: 10 x 9.5 x 2.5mm
  • Color: Black
Scope of delivery
  • Alphacool Eiskamm Alu X4 - 4mm black - 4 pieces
Datasheet
Assembly instructions
€0.99 * €5.02 *
86%
€0.99 * €6.96 *
83%
KAB Alphacool Eiskamm Alu X6 - 4mm black - 4 Stück PHT EOL
Alphacool Eiskamm Alu X6 - 4mm black - 4 pieces
€0.99 * €5.94 *
90%
€0.99 * €9.94 *
€0.99 * €5.02 *
88%
€0.99 * €8.00 *
78%
Alphacool Eiskamm Alu X4 Flat - 4mm red - 4 pieces
€0.99 * €4.59 *
€0.99 * €4.89 *
€0.99 * €5.02 *
€0.99 * €5.02 *
89%
Alphacool Eiskamm Alu X14 - 4mm black - 4 pieces
€0.99 * €9.02 *
€0.99 * €5.02 *
Phobya VGA Power Connector 6+2Pin plug incl. 8 pins - 2 pieces Black
Content 2 Stück (€1.44 * / 1 Stück)
€2.87 *
Alphacool Eiskamm Alu X4 - 4mm red - 4 pieces
€0.99 * €4.89 *
Alphacool Eiskamm Alu X5 Flat - 4mm silver - 4 pieces
€0.99 * €5.02 *
90%
Alphacool Eiskamm Alu X16 - 4mm silver - 4 pieces
€0.99 * €9.94 *
75%
Alphacool Eiskamm X4 Flat - 3mm black - 4 pieces
€0.99 * €3.99 *
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
24%
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
Content 16 cm² (€0.24 * / 1 cm²)
€3.78 * €4.97 *
37%
Alphacool Eisschicht Ultra Soft thermal pad 3W/mk 100x100x1,5mm
€15.78 * €24.98 *
52%
Hint!
€4.80 * €9.98 *
