Alphacool Eiskamm X4 Flat - 3mm black - 4 pieces
- Article no.: 24758
- EAN: 4250197247580
- Weight: 0,002 kg
*1What is that?
Highlights
- Nylon is flexible and cannot break
- Easy installation without modifications
- Simple and clean laying of cables
- Material: Polyester
- Variant: X4 Flat
- Dimensions: 19 x 4.75 x 2mm
- Color: Black
Scope of delivery
- Alphacool Eiskamm X5 Flat - 3mm black - 4 pieces
