  • 24743
  • 4250197247436
  • 0,002 kg
  • Currently there are 8 available
€0.99 * €3.89 * (74.55% Saved)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X6 Flat
  • Dimensions: 14 x 8 x 2mm
  • Color: Clear
Scope of delivery
  • Alphacool Eiskamm X6 Flat - 3mm clear - 4 pieces
Datasheet
Assembly instructions
78%
€0.99 * €4.49 *
67%
Alphacool Eiskamm X5 Flat - 3mm clear - 4 pieces
€0.99 * €2.99 *
€0.99 *
75%
Alphacool Eiskamm X4 Flat - 3mm clear - 4 pieces
€0.99 * €3.89 *
€34.98 *
€25.98 *
€4.97 *
€3.78 *
€3.88 *
Alphacool y-splitter 4-Pin to 2x 4-Pin PWM 30cm white
€2.98 *
€2.58 *
€6.99 *
€5.99 *
€5.68 *
€4.48 *
€5.99 *
Alphacool y-splitter aRGB 3-pin to 2x 3-pin 60cm
€4.68 *
€3.97 *
€3.47 *
€2.98 *
€2.78 *
€2.58 *
€1.68 *
€1.48 *
