- Article no.: 24745
- EAN: 4250197247450
- Weight: 0,002 kg
*1What is that?
Highlights
- Nylon is flexible and cannot break
- Easy installation without modifications
- Simple and clean laying of cables
- Material: Polyester
- Variant: X12 Flat
- Dimensions: 26 x 8 x 2mm
- Color: Clear
Scope of delivery
- Alphacool Ice Comb X12 Flat - 3mm clear - 4 pieces
