Alphacool Ice Comb X6 - 3mm black - 4 pieces
- Article no.: 24752
- EAN: 4250197247528
- Weight: 0,002 kg
What is that?
Highlights
- Nylon is flexible and cannot break
- Easy installation without modifications
- Simple and clean laying of cables
- Material: Polyester
- Variant: X6 Flat
- Dimensions: 14 x 8 x 2mm
- Color: Black
Scope of delivery
- Alphacool Eiskamm X6 Flat - 3mm black - 4 pieces
