  • 24756
  • 4250197247566
  • 0,002 kg
€0.99 * €5.02 * (80.28% Saved)
What is that?
Highlights
  • Nylon is flexible and cannot break
  • Easy installation without modifications
  • Simple and clean laying of cables
  • Material: Polyester
  • Variant: X16 Flat
  • Dimensions: 34.5 x 8 x 2mm
  • Color: Black
Scope of delivery
  • Alphacool Eiskamm X16 Flat - 3mm black - 4 pieces
Datasheet
Assembly instructions
75%
€0.99 * €3.99 *
€0.99 * €5.02 *
75%
Alphacool Ice Comb X6 - 3mm black - 4 pieces
€0.99 * €3.99 *
75%
Alphacool Ice Comb X4 - 3mm black - 4 pieces
€0.99 * €3.99 *
Alphacool Ice Comb X14 - 3mm black - 4 pieces
€0.99 * €5.02 *
75%
Alphacool Eiskamm X5 Flat - 3mm black - 4 pieces
€0.99 * €3.99 *
€1.98 *
75%
Alphacool Eiskamm X4 Flat - 3mm black - 4 pieces
€0.99 * €3.99 *
90%
€0.99 * €9.94 *
€2.28 *
Delivery date: in 5 - 6 weeks
€6.49 * €8.98 *
€1.98 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Electric Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
56%
Alphacool AlphaCord Sleeve 4mm - 3.3m (10ft) - Colonial Blue (Paracord 550 Type 3) 330cm
€1.98 * €4.47 *
€0.99 * €4.89 *
88%
€0.99 * €8.00 *
85%
€1.98 * €12.98 *
