Alphacool Eiskoffer - measuring tool 140mm
- Article no.: 90359
- EAN: 4250197136907
- Weight: 0,015 kg
Measuring tool 140mm For measuring the distances between the fittings you want to connect.... more
For measuring the distances between the fittings you want to connect. You can also connect the measuring tongues to each other or mount them on the bending plate to transfer measurement results.
Content
30 Zentimeter
(€26.60 * / 100 Zentimeter)
€7.98
Content
30 Zentimeter
(€29.93 * / 100 Zentimeter)
€8.98
Alphacool Eiszapfen 16mm HardTube compression fitting 90° rotatable G1/4 for Acryl/Brass tubes - 4pcs Set Chrome
Content
4 Stück
(€9.00 * / 1 Stück)
€35.98
Content
320 Zentimeter
(€12.18 * / 100 Zentimeter)
€38.98
Content
6 Stück
(€2.50 * / 1 Stück)
€14.98
Content
100 Milliliter
(€99.80 * / 1000 Milliliter)
€9.98
Content
320 Zentimeter
(€8.12 * / 100 Zentimeter)
€25.98
Content
6 Stück
(€6.33 * / 1 Stück)
€37.98
Alphacool Silicon Bending Insert 150cm for ID 1/2" / 13mm HardTubes - Blue
Content
150 Zentimeter
(€11.32 * / 100 Zentimeter)
€16.98
Content
6 Stück
(€6.16 * / 1 Stück)
€36.98
