Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
  • 18546
  • 4250197185462
  • 1,1 kg
Content: 1000 Milliliter
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
UV inkNot UV active
Content1000ml
SpecificationReady mix
Coloryellow
ManufacturerAlphacool
€69.98 *
€28.98 *
€6.49 * €8.98 *
€39.98 *
