Phobya Y-cable 3Pin Molex to 4x 3Pin Molex - Black 60cm
- Article no.: LK
- EAN: 4049469077976
- Weight: 0,025 kg
For connecting four 3-pin fans (radiator fan, case fan, etc.) to the mainboard connector (3-pin). Please note that when using the cable, speed monitoring is only possible for one of the connected fans.
A white sticker on the cable indicates which one transmits the speedometer signal.
Sleeve:
This cable is not only functional, but also very visually appealing. The mesh that wraps around the actual cable is very dense and offers exactly the effect that professional sleevers want: complete conversion of the cable to emphasize the uniqueness of their system even better! Particular attention was paid to the combination of the cable sheath (the sleeve), the connector and the shrink tubing so that they create a uniform image.
Sets:
Technical details:
Connectors: 3 pin to 4x 3 pin Y-cable
Colour: black sleeve, black connectors, black shrink tube
Dimensions: 30cm each
RoHS compliant
1x Phobya Y-cable 3Pin Molex to 4x 3Pin Molex 60cm - Black
Note: When using this distributor, please pay attention to the requirements of the slot, on the mainboard or the fan controller. Excessive loads, pay attention to the wattage of the fans, can lead to damage.
This product was tested for you:
Aqua info
Tech Review
Bauform: | Y-Kabel |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
2. Seite: | 4x 3Pin |
Hersteller: | Phobya |
