Phobya Adapter 4Pin Molex (12V) to 4Pin PWM - Black 30cm
- Article no.: LK
- EAN: 4049469124359
- Weight: 0,013 kg
For connecting fans 4-pin PWM connector (CPU cooler, case fan, etc.) to power supply connector (4-pin) to power supply connector (4-pin Molex).
Sleeve:
Sets:
Phobya's goal is to accommodate hobby and professional case modders a little. Sleeving is a lot of work and takes a lot of time, so with Phobya's cables you can now rebuild your entire system the way you want, just by replugging it.
Technical details:
Connectors: 4 pin to 4 pin Molex from 4 pin Molex to 4 pin PWM connector (12v)
Colour: black sleeve, black connectors, black shrink tube
Dimensions: Molex to Molex 7cm, Molex to 4Pin PWM 30cm
RoHS compliant
1x Phobya adapter 4Pin Molex (12V) to 4Pin PWM 30cm - Black
1. Seite: | 1x 4Pin |
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
Sleeving: | schwarz |
Hersteller: | Phobya |
