Phobya Y-cable 3Pin Molex to 3x 3Pin Molex - Black 60cm
- Article no.: LK
- EAN: 4049469126339
- Weight: 0,019 kg
For connecting three 3-pin fans (radiator fan, case fan, etc.) to the mainboard connector (3-pin). Please note that when using the cable, speed monitoring is only possible for one of the connected fans.
Sleeve:
Sets:
Technical details:
Connectors: 3 pin to 3x 3 pin Y-cable
Colour: black sleeve, black connectors, black shrink tube
Dimensions: 60cm each
RoHS compliant
1x Phobya Y-cable 3Pin Molex to 3x 3Pin Molex 60cm - Black
Note: When using this distributor, please pay attention to the requirements of the slot, the mainboard or the fan controller. Excessive loads, pay attention to the wattage of the fans, can lead to damage.
Aqua info
Tech Review
Bauform: | Y-Kabel |
Sleeving: | schwarz |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
2. Seite: | 3x 3Pin |
