Phobya adapter 3Pin (12V) to 3Pin (7V) 20cm
- Article no.: 81067
- EAN: 4049469099848
- Weight: 0,005 kg
€3.48 *
Content:
20 Zentimeter
(€17.40 *
/ 100 Zentimeter)
For connecting a fan with a 3-pin Molex connector (CPU cooler, case fan, etc.) directly to the... more
For connecting a fan with a 3-pin Molex connector (CPU cooler, case fan, etc.) directly to the motherboard. This adapter allows a fan to be operated with 7 volts instead of 12 volts, which reduces noise. The big advantage of this adapter is that the speed of the fan can still be monitored. Please note that the rotation speed of the fan will be lower and therefore the air flow rate will be reduced.
Technical data:
Length: 20cm
Special features: Reduces the voltage from regular 12 volts to 7 volts
Connection type: 3 pin standard
Length: 20cm
1x Phobya adapter 3Pin (12V) to 3Pin (7V) 20cm
Sleeving: | ohne |
2. Seite: | 1x 3Pin |
Bauform: | Adapter |
1. Seite: | 1x 3Pin |
Hersteller: | Phobya |
Phobya extension 3Pin - UV Blue 30cm
Content
30 Zentimeter
(€2.17 * / 100 Zentimeter)
€0.65
Phobya Y-cable 3Pin Molex to 9x 3Pin Molex - Black 60cm
Content
60 Zentimeter
(€13.30 * / 100 Zentimeter)
€7.98
Phobya Adapter 3Pin (12V) to 3Pin (7V) - Black 20cm
Content
20 Zentimeter
(€17.40 * / 100 Zentimeter)
€3.48
Phobya Y-Adapter 4Pin Molex to 4x 3Pin (12V) - Black 30cm
Content
30 Zentimeter
(€20.93 * / 100 Zentimeter)
€6.28
Alphacool Y-Splitter 3-Pin to 3x 3-Pin 15cm
Content
15 Zentimeter
(€16.53 * / 100 Zentimeter)
€2.48
Phobya Y-cable 4Pin PWM to 6x 4Pin PWM - Black 60cm
Content
60 Zentimeter
(€12.47 * / 100 Zentimeter)
€7.48
Phobya Fan Power Connector Pin Socket - 20 pieces
Content
20 Stück
(€0.12 * / 1 Stück)
€2.48
Phobya Fan Power Connector 4Pin PWM Socket - 2 Pieces Black
Content
2 Stück
(€0.99 * / 1 Stück)
€1.98
Content
20 Zentimeter
€3.48
Content
30 Zentimeter
€0.65
