Yate Loon D12SH-12 with plug (2200rpm) (120x120x25mm)
  • 78050
  • 4049469030285
  • 0,155 kg
€3.00 *
LZ Alphacool Susurro Antinoise Silicone Fan Frame - 120mm - universal EOL
€3.97*
New fan from the house of Yate Loon. Strong performance and whisper-quiet operation characterize... more
New fan from the house of Yate Loon. Strong performance and whisper-quiet operation characterize this 120mm axial fan with bronze bearings. The fan can be connected via the 3-pin Molex connector both to a power supply (with appropriate adapters, if not available) or directly to the motherboard. The fan is also ideal for Super Silent operation at < 7V. Thanks to the extra-long connection cable of approx. 60cm, the fan can also be wired neatly in larger cases (e.g. servers or big towers) without the need for an extension cable.
Technical data:
Dimension: 120x120x25mm
Supply voltage: 12V
Speed: 2200 rpm
With 3 pin Molex connector ca 60cm cable and speed signal.
Rated speed range: 2000 - 9000 U/min
Manufacturer: Yate Loon
Air conveying area: 100 - 149 m³/h
Air flow rate: 149,5 m³/h
Color Frame: Black
Rated speed: 2200 U/min
Color Rotor: Black
Nominal voltage: 12V DC
Volume: 40 dB(A)
RPM signal transmission: Yes
Volume range: 30 - 49,9 dB(A)
Power connection: 3Pin
Dimensions: 120 x 120 x 25mm
LED: Unavailable
Fan bundle: 3x, 4x, 9x
€6.49 * €8.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
hose PUR 10/8mm (5/16&quot;ID) Clear sold by the meter
€1.79 *
39%
ANF Alphacool ES D-Plug 31,5mm G1/4 AG auf G1/4 AG - Deep Black
Alphacool ES D-Plug 31.5mm G1/4 AG to G1/4 AG - Deep Black
€4.97 * €8.18 *
Liefertermin: in 6 - 7 Wochen
40%
Alphacool Ice Water Crystal Blue Ready Mix 1000ml
Alphacool hose AlphaTube HF 13/10 (3/8&quot;ID) - Clear 3m (9.8ft) Retailbox 300cm
Alphacool hose AlphaTube HF 13/10 (3/8&quot;ID) - Clear sold by the meter
14%
PUZ Alphacool Pumpenbefestigung Universal für 120-140er Lüfter/Radiatoren
Alphacool pump mount universal for 120-140mm fans/radiators
€11.98 * €13.99 *
