Alphacool ice cyclone Aurora LUX Digital RGB (140x140x25mm)
- Article no.: 24809
- EAN: 4250197135993
- Weight: 0,21 kg
The Alphacool Eiszyklon Aurora LUX fan offers extensive RGB lighting and is ideal as a silent fan. With a wide control range up to a maximum of 1500 rpm, it can be operated from powerful to pleasantly quiet. The frame of the fan is of course decoupled, which further underlines its silent suitability.
Addressable digital RGB lighting
RGB was yesterday, the future lies in addressable digital RGB LEDs that can be controlled individually. Therefore, the Eiszyklon Aurora LUX fan naturally uses digital aRGB LEDs. A diffuser is used to ensure that the frame of the fan is optimally illuminated. The milky white fan frame scatters the light over the entire fan frame and ensures perfect and comprehensive illumination of the entire fan. Since each LED can be controlled individually, all known effects are possible. These include effects such as wave, pulse, breathing and much more.
Flow-optimized fan blades
The fan blades have been specially adapted for use on radiators. The most important point is a high static pressure. In order to achieve this even at low speeds, the fan blades are slightly curved. This means that they act like a shovel that draws the air inwards and presses it downwards with excess pressure. The 9 closely spaced fan blades also ensure a continuously high static pressure even at low speeds. This means that the air can be optimally pushed through a radiator. Of course, the Eiszyklon Aurora LUX fan is also suitable as a case fan.
Connections?
The fan is controlled via a 4-pin PWM connection. The cable is 44 cm long. This means that the fan can be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Technical Data:
- Dimensions: 140 x 140 x 25 mm
- Speed: 1500 rpm
- Static pressure: 1.93 mm H2O
- Air flow: 118.93 m³/h
- Bearing: Hydraulic
- Connectors: 4-pin PWM, 3-pin JST
- Lighting: Digitally addressable 5V RGB LEDs
- Weight: 180g
Download data sheet PDF: Alphacool Eiszyklon Aurora LUX Digital RGB (140x140x25mm)
Rated speed range: | 1000 - 1450 U/min |
Made in: | China |
Air conveying area: | 50 - 99 m³/h |
Air flow rate: | 98,54 m³/h |
Pressure: | 1,22mm H2O |
Color Frame: | Black; |
Rated speed: | 1100 U/min |
Color Rotor: | Black; |
Nominal voltage: | 12V DC |
Size: | 140mm |
Volume: | 21,0 dB(A) |
RPM signal transmission: | Yes |
Volume range: | 20 - 29,9 dB(A) |
Starting voltage: | 9,6V |
Lebensdauer (bei 25°C): | 50.000 h |
Power connection: | 4-pin; |
Dimensions: | 140 x 140 x 25mm |
LED: | RGB; |
Power consumption: | 1,92W |
Fan bundle: | nein; |
Delivery date: in 8 - 9 weeks
Delivery date: in 5 - 6 days
