Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 30cm
  • 18538
  • 4250197185387
  • 0,024 kg
€2.48 * €6.49 * (61.79% Saved)
Content: 30 Zentimeter (€8.27 * / 100 Zentimeter)
The new Alphacool Y-cable for 4-pin RGB connections allows up to three individual RGB components... more
The new Alphacool Y-cable for 4-pin RGB connections allows up to three individual RGB components from the Alphacool RGB family to be combined into one input. This means that these three components can be connected to an RGB output from, for example, a motherboard, graphics card or RGB controller using an Alphacool Y-cable. This means that RGB solutions such as ASUS AURA, MSI MYSTIC LIGHT or GIGABYTE/ AORUS RGB FUSION can be used to synchronize Alphacool RGB products.
The cable comes with 4 male / female connector bridges.
  • Connection
    Side 1: 1x 4-pin
    Page 2: 3x 4-pin
  • Design: Y-cable
  • Length: 30cm
  • Sleeve: black
  • 4x male connector
Scope of delivery
  • 1x Alphacool Y-cable RGB 4-pin to 3x 4-pin 30cm incl. connector - black
54%
Alphacool RGB 4-pin LED adapter cable for motherboards - Black 50cm
Content 50 Zentimeter (€3.96 * / 100 Zentimeter)
€1.98 * €4.28 *
83%
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 30cm
Content 30 Zentimeter (€3.30 * / 100 Zentimeter)
€0.99 * €5.89 *
86%
KAB Alphacool Y-Kabel RGBW 5pol auf 3x 5pol inkl. Stecker - Schwarz 60cm EOL
Alphacool Y-cable RGBW 5-pin to 3x 5-pin incl. connector - black 60cm
Content 60 Zentimeter (€1.65 * / 100 Zentimeter)
€0.99 * €6.89 *
€5.48 *
€1.48 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
54%
€1.98 * €4.28 *
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
63%
€1.58 * €4.28 *
Alphacool Y-Splitter aRGB 3-Pin to 4x 3-Pin 30cm
€5.99 *
€2.78 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
Content 15 Zentimeter (€13.00 * / 100 Zentimeter)
€1.95 * €2.78 *
51%
Alphacool Eis-Matrix connection cable to 4-pin RGB - 10cm
Content 10 Zentimeter (€9.80 * / 100 Zentimeter)
€0.98 * €1.98 *
23%
PUM Alphacool Core 200 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP/D5 Apex PWM Pumpe
Alphacool Core 200 Aurora reservoir acetal/acrylic with Apex pump
€95.98 * €124.99 *
€6.99 *
34%
Alphacool Ice Cyclone Aurora LUX Digital RGB - Kit of 3 (120x120x25mm)
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
